OK, so I’ve made that classic mistake (not for the first time) of compressing my Rockshox RCT3 fork before fully assembling the damper and firing that shaft that adjusts the threshold across the shed again 😳 It makes a fair old bang ! Having checked my head for any extra holes, I located the shaft, put it all back together and it’s working fine, except that there are no clicks when I rotate that little silver (threshold?) adjuster at the top.
If I remember correctly, I think there is a little spring loaded ball bearing in the shaft that gives the clicks, but there is no chance I’ll find that in the shed and it doesn’t seem to be in either of the service kits I’ve got. So, does anyone know of a source for these little fellers?
