Soon to rebuild my helmet light and wondered what you guys would think is the ideal position for a one inch long on/off switch.It has a thumb operated switch and is held by the fingers in a cletched fist motion. I usually use this alot during a ride and i.e. do not just turn it on/off once.
Previously had the switch about two inches from the actual light bulb, behind the bulb, with all the wires going straight back into my backpack behind my head and to the cells which worked well.
This worked well as i just pushed my hand up and if i couldn’t find the switch just felt the lapmp unit casing which then led the the switch. Also the switch was faced backards so felt naturqal for my thumb to operate it.
Just wondering if I could improve this at all.
I could also run wires under my arm from the backpack and to the side of my neck, thus enabling a switch to be positioned near my chest or clipped on to the chest hardness of my backpack. However don’t like the idea of pulling my hand into my body so much and the underarm wires may be a bit prone to snagging and clashing with the hydration pack’s pipe.
Any ideas/ views?
