break them off where they want to snap (about 5inches from the tip of the spear), peel the spears up to about 1/2 an inch from the tip, into boiling water till cooked (wobble nicely when held by the cut end). Shock in iced water.
Reduce the water you'd cooked the asparagus in right down.
grate Parmigiano-Reggiano on to a silicon baking sheet (on a tray) and make it into a circle about 3 inches round and about 1cm in height, put some thinly sliced Pancetta on the other end and pop them in the oven till cooked, the cheese will be a lightly golden crisp and the Pancetta should not be burnt.
poach a couple of quails eggs.
cook the Asparagus in a pan with some butter and a little of the stock with some shelled broad beans.
put the spears onto a bowl plate, add the beans and the sauce, put the eggs, bacon and then the cheese on top.
eat.
