I’m looking for something to replace the PAR cable in my Marzocchi forks.
It needs to be fairly fine, 2mm or so, and able to take 30kg or so. It also needs to be able to withstand, as well as possible, going through the hole in the fork shaft which is reinforced with a curved eyelet but the radius isn’t that great so it’s a reasonable corner to have to go around. I’ve got clothes line in there now but it’s showing signs of fraying after not too long. It also needs to be floppy so possibly something braided would be best.
I was thinking of looking in the fishing world, but I’ve got no idea what’s what. There seems to be braided cord on sale but they list strength as 20lb. ISTR reading that doesn’t mean it snaps at 20lbs of load though – is that right?
I’d like to pick something up today, Go Outdoors have fishing stuff and camping so there’s a *chance* they’ll have dyneema cord. They do climbing stuff afaik so maybe.
Depends how abrasion resistant it needs to be, but spectra/dyneema (trade neames of ultra high molecular weight polyethylene) would be strong enough, not sure about abasion resistance, I use a lot of it on my boat but it’s not keen on sharp corners so prefers being spliced rather than knotted. Normal pre-stretched polyethylene rope would be adequate and half the price. You can get wire fishing line too, braided fishing line is just multiple nylon fillaments, wire would probably be more abrasion reistant, but doesn’t like being bent repeatedly.
@molgrips – go to a sailing shop (chandlery) there are some in Cardiff (or ask the yacht club) they will have dyneema. What I cannot answer is how much chafe you’ll have – you say abrasion resistant ? Dyneema isn’t chafe resistant and in fact from your pic neither is what they used. It’s not uncommon to cover the dyneema in something (inc plastic tubing) which you then replace regularly as that chafes. Generally you don’t tie knots in dyneema type line but splice it.
EDIT: resistance to tight corners – again not a quality modern high tech line is good at. That’s why boats use “turning fittings” to round out corners.
The dyneema is really strong in terms of load bearing, you might just have to inspect it and swap it out as/when the chafe (abrasion) starts to damage it. FYI that’s what you do in many boat applications
When I look at your photo I can see it’s been spliced on at the bottom
Oi, pop along to a Yacht Chandlers or kite/windsurfing shop, it’s used all the time that stuff. You can get it in sizes from 1mm right upto 25mm and it’s not only used for Kitesurfing/Windsurfing but loads of ropes/warps in Dinghies and Yachts too.
Go for the core only and not the braded/core type and you’ll also save some weight.
HTH
Failing to find a Chandlers try online at Rooster Sailing or Aladins Cave.
Thanks for the kind offers folks. I was hoping to get my forks built tonight, so just stopped by the archery shop and the fishing shop.
I’ve got 150lb leader which can be crimped (this is a plus) but isn’t that flexible being monofilament. I also got some archery cord but it’s really a bust. Bowstrings are made of bundles of fibres, each one I can easily break. However I could braid them together, and perhaps even weave it back into itself to avoid having to use knots. Interesting idea.
I checked Go Outdoors, and they only advertise 2mm nylon cord rather than dyneema. Also called our local specialist shop and they didn’t have anything thin enough either.
Seeing as everyone is recommending dyneema I’ll be deliberately contrary and suggest animal sinew. You could try raking through the bins behind the local butchers.
As above, the archery bow string was made of a bundle of smaller maybe 1mm cords with a very loose twist, so I considered plaiting them. Then I thought that instead of a knot I could make a loop in each end of the cable and thread the three ends back through the plait, which is kind of how the original one was made.
A bit of googling revealed that this is called an eye splice, and since most instructions show it done with braided rope (rather than plaited) I thought I’d try making a three string braid. Well my rope work was pretty dodgy as you’d expect, and the splicing looked a right mess but to my astonishment, it seems to hold really well! For good measure I’ve bound the splice with the very fine thread that was originally holding the bow string together.
