My topeak morph is/was great when it worked. The main seal and the seals on the valve head end seals have worn out now though, and I’m assuming this is causing it to leak a little pressure and when upto 30+psi it gets a real pain trying to hold the pressure back with the handle
Before that, the foot handle snapped off, the handle retention clip bit (for folding up) snapped off, and you can easily hit your knuckles on the main body of the pump when you hold the handle when pumping
The valve still works though. I’ve had it this one (warranty) for 2 years, the one before wore out in 7 months ish or so. I need to find a main seal and valve seal kit for this one and I reckon It’d be fine after that
