I’m a procore convert. they are expensive but
[*]actually easy to fit, despite the hype (no need for compressed air) although this might depend on rim choice and maybe I got lucky
Run low pressures, crazy grip levels. I’m running +/- 1 bar.
Puncture protection; OK I do pretty well on standard tubeless
Rock solid bead retention. you could run the main chamber completely flat, the bead would still be locked to the rim by the inner chamber (this is actually the reason I first tried them, after a burp/fall/bones broken incident 3 years ago[/*]
Downsides they are pricey (even shopping around you’re still spending 100 euro/wheel) and they do add weight, but for me it is weight well spent to get the functionality
so in the end a bit like a dropper post. expensive and heavy but bloody hell it works so well I almost can’t imagine being without it
