I am building up a commuter/tourer/general purpose bike with a hub dynamo.
From the hub dynamo I will want to run a front and rear light, and some sort of usb charging port for sat nav. I don’t expect to be running lights at the same time as charging other stuff, so power drain shouldn’t be a problem.
Anybody done this kind of setup? I would like to keep it as clean as possible. Is it possible to charge a Germin unit from the output of an exposure revo?
Are there any decent alternatives to the revo that are permanently wired and fixed?
I’ve got the SP PD-8 hub, wired up to an Exposure Revo. I run an Exposure Redeye from the Revo’s smartport thingy.
For charging, I’ve got a Kemo M172N which connects inline between the hub and Revo if I need it.
I’ve also got the previous model M172, but I snapped the USB plug on it and bought the replacement/upgrade rather than wiring ona new wire as I needed it in a hurry (for the LEL)
Happy to fix and sell the M172 if you’re interested…
I’m building a similar setup at the moment. I have on pre-order the Shutter Precision PD-8X which is the 15mm axle version of the hub that exposure have re-branded and sell with the Revo.
So I can run just the light, or fit the Kemo in to give me the option of the lights or charging.
I used the setup for riding the LEL the other month, using an phone as a GPS and had no problems.
If you want to keep it clean, how about a light with a built-in USB port, so you can choose whether charge or illumination? Axa light – the nano version is cheaper, but less bright.
I have the setup you are after on my MTB, I have used it racing, all day epics, multi-day bikebacking touring and day to day commuting.
I have tried a few different chargers, but fur ruggedness, mall size and value for money, I would recommend the Kemo 172, you need to cut and connect the wires into the Exposure cable, but well worth the fuss. The Exposure Boost cable will keep a Garmin charged, but would struggle with a smart phone, plus I recommend using the power port to connect to the long cable redeye rear light, so you have a dynamo powered, sper bright, rear light too.
