deflate
push firmly all around one side on the beading trying to dislodge, press beading into centre of the rim where there will likely be a channel, repeat other side
in the worse case cut if off because if you can’t get it off on the trail it’s useless anyway
its really tight on. is that normal??
It can happen, depends on the tyre/rim combo.
But I wouldn’t run a tyre that I couldn’t get off the rim trailside, in case I slashed it irreparably and needed to put a tube in.
can anyone offer advice on changing and reinstalling.
many many threads here, do a search
i guess i will need new sealant gunk as well??
Yes.
