Why couldn’t you use the FSA adaptor in the CRC link? (Genuine question – I don’t know if it would work.)
The internal diameter of the Praxis one narrows in the middle, which is why a cartridge square taper bottom bracket will not fit it according to the CRC Q&A page.
The FSA one will accept a square taper cartridge according to the CRC Q&A page, but the OP was concerned about it being semi-permanent. Personally, I would not want to use a cartridge bottom bracket in such an adapter, since I cannot help thinking that the repeated torque applied in installing and removing the cartridge to replace it when it has reached the end of its life or develops a fault, is going to lead to problems with the press fit at some point.
