For those kind enough to give me advice a week ago, I thought I’d post a quick update…
Little Shimano plasticky axle removal tool (as pictured above by Julain Wilson) arrived at LBS today, right on time, and was mine for the princely sum of three quid.
Took the pedal apart, tightened up the cone on the bearings a little, added a bit of locktite blue to the locknut to stop it losening again, and re-assembled. Took about half an hour all up, and cost three quid!
So, I’d say M520 pedals are definitely serviceable, and the essential tools required are:-
15mm pedal spanner
Shimano TL-PD40 axle removal tool
10mm and 7mm spanners (for cone and locknut respectively)
A bit of grease, and a dab of loctite blue
Note, you don’t need the expensive bearing adjustment tool (as pictured above by Dibbs), at least not for the M520s.
I also have to say that having seen the engineering, number of components, and obvious thought that’s gone into the internals of a relatively cheap pedal, I have a new respect for the guys at Shimano, and the price they sell them for!
So, what are you waiting for guys – rainy weekend – get servicing those pedals….
