I have a GT Avalanche 3.0 Disc 2009 18" which has seen at least 800+ miles cross country and a bit on road. I paid £300 for it. It has a few scratches shown below. I have recently replaced the tyres (they've seen 3-4 rides) and the disc pads about 6 months ago. The forks are quite temperamental and basically have lost most of the rebound in the coil spring (What you get from cheap Suntour forks). How much is it worth?
Heres the spec – ….
Frame:
GT Triple Triangle design 6061 aluminium with hydro formed downtube and zero stack headtube. Disc compatible with removable hanger.
Fork:
SR Sumtour XCM one piece aluminium lowers with disc mount and preload adjust, 100mm travelad adjust, 100mm travel
Front Derailleur:
Shimano M – 330
Rear Derailleur:
Shimano Alivio
Shifters:
Shimano rapidfire shifters
Chainset:
Suntour XCT – 308
Chainrings:
42/32/22
Bottom Bracket:
Cartridge Sealed
Cassette:
Shimano Eight Speed 11-32 ratio
Chain:
IG-31
Pedals:
High Impact nylon platform
Front Brake:
Tektro Linear Pull
Rear Brake:
Tektro Linear Pull
Brake Levers:
Alloy with reach adjust
Handlebars:
Alum 31.8mm with 20mm rise, 6 degree bend and anatomically sized
Stem:
GT ATB 31.8mm bar bore threadless 15 degree rise with four bolt alum face plate
Headset:
Tange Seiki system for 1 1/8"
Grips:
GT Dual Density ATB
Rims:
Alex ASD-1
Front Hub:
Alloy QR
Rear Hub:
Alloy 8 speed cassette with QR
Spokes:
Stainless Steel Gauge 14
Front Tyre:
Kenda Nevegal 26 x 2.1
Rear Tyre:
Saddle:
WTB Speed V
Seatpost:
Alloy Micro adjust
Seat Binder:
GT Forged Alum QR
http://www.facebook.com/album.php?aid=418739&id=635830710&l=a45c5eacc8
Use that link to see the pictures of the bike.
Thanks.
