Thanks…prices shouldn’t be too scary then 🙂
Well reading the forums, seems once it starts miss-firing, changing the above will temporarily fix it, then a few hundred miles later it will return and people start changing sensors, then it comes back and they clean the EDC plug, then they sell the car pronto before it comes back again!
Our car has had a long term niggle where it hesitates at low speed/gentle throttle and there are guys that have replaced the leads etc, problem remained, and then replaced with genuine Ford parts and thats fixed it. Also, I’ll end up replacing all the bits, then when the problem comes back I will end up buying genuine bits ‘just in case’!
I tried pulling away in it yesterday and its missfiring so bad it is virtually undrivable. It does an 80 mile round commute each way so if my fix is only temporary it will probably be returning behind an AA van, plus my wife is now on the train (standing room only) everyday and that is costing a fair bit.
Its the 1.6 (sigma?) Duratec as fitted to 2002>2008(?) Fiesta’s, Fusion, Focus. Car is racking up the miles on a long commute with 85k on the clock.
