It comes with a single ring crank, and I’m pretty certain that I need a double. So I ordered a Race Face Evolve 24-36-Bash and put it on. It fits. 🙂 But there is only about 1 mm (the thickness of a zip tie) of clearance between the chainring and chainstay. 😯
Would anyone be comfortable with so little clearance on their bike?
I’m leaning toward getting a 34 tooth ring instead…
I ran a ring with about 3mm gap on an Inbred and the ring rubbed when out of the saddle. I guess I’d be looking for 5mm to mitigate against any issues.
Druidh – I installed it stock per this. I could move spacers, but then the crank arms would be offset from the frame centerline. While I appreciate that this won’t be noticeable when riding, it would drive me crazy knowing that the cranks aren’t centered. So if someone else had built the bike and not told me, it would be fine. Since I know, no. Good idea, though.
wwaswas – I’m switching the bike to a Simano Shadow+ rear der. That should make chain suck a lot less likely. And the chainstays are effin’ huge square things! I can’t remember the last time I had chain suck on my regular bike, but its 8 speed.
rich – yes it would have to be a biiiig BFH. As above, the stays are huge.
mtbfix – I’d guess that the Fatty stays are a lot bigger than the Inbred, so less likely to flex IMO. We’ll see when I ride.
My 853 Inbred had precisely 2.5mm of clearance when new. (It was exactly the thickness of a HT2 spacer)
Chain suck was almost uncontrollable and despite me changing rings 3 times in a year at the first sign, it gnawed through the chain stay. One it was so bad I had to remove the cranks to get the chain out.
I had a new stay put in that didn’t have the S bend in it. I lost 2-3mm of mud room but gained a lot of chain room.
4 years later the new stay is virtually unmarked and I can leave middle rings until they are utterly shot.
Why O-O have this blinkered fixation with mud room, at all costs, I can’t imagine. And super short head tubes, but that’s a different story.
druidh – I installed the crank the way RF recommended, with spacers in the following configuration:
NDS 1 mm Spindle spacers – 1 (factory installed on spindle)
NDS 2.5 mm BB Cup spacers – 1
DS 2.5 mm BB Cup spacers – 2
DS 1 mm Spindle spacers – 2 (factory installed on DS crank)
Per the RF pdf cited above, the crank clearance should be within 0.2 mm of each other.
So, I took my digital caliper and measured from the pedal side face of the crank to the seat tube. They were only 0.06 mm* off! 😯
I then used the highly scientific and very repeatable method of sticking a finger between the crank arm and chain stay and determining that they are the same distance as well. 😀
*I do realize that my measurement accuracy is probably not even that good. Even slightly different paint thickness on the two sides of the seat tube would affect the measurement this much, FFS. And I doubt that my caliper was held perfectly square, etc. Bottom line is that the crank is centered within a pretty small tolerance.
