Viewing 31 posts - 41 through 71 (of 71 total)
  • How many molecules of water are there in the ocean..?
  • mikey74
    Really? I was under the impression that sand became progressively finer until it became silt, then eventually clay. Whereas the other end of the spectrum it becomes larger and turns into grit, then maybe gravel.
    You are correct.
    crazy-legs
    Th properties of water are discerned by the interaction between the composite molecules of H20. One single molecule of H20 does not exhibit the same properties as water.
    That’s not really an argument TBH – one molecule of water is still a water molecule and anyway, not ALL it’s properties are defined by molecular interactions. After all ice/steam is still H2O but neither exhibits the same properties as liquid water so your original argument falls down slightly.
    molgrips
    Sure. Doesn’t mean it’s not still water though. Especially as only some of the properties of water are macroscopic.
    This is true, and if I’d been thinking a bit more carefully I’d have remembered.
    Therefore if you only have 1 silicon atom, and 2 oxygen atoms to make one SiO2 molecule you can’t make quartz, and therefore you can’t make sand
    Yes, one molecule of SiO2 is not sand as described above, but one molecule of water is still water. Sand is the name for a particular arrangement of SiO2 molecules.
    molgrips
    would it be easier to swim if all water was carbonated?
    There is a spring somewhere in South America or Indonesia which spews out carbonated water.
    Junkyard
    we have several imprecise numbers:
    How many shoes do I have if I have a few pairs ?
    Always confused me that one
    Re water it is a lot anything else is just a guess- some of which arebetter guesses than others
    mudshark
    Anyone tried putting a gold fish into carbonated water? I’m curious.
    deadlydarcy
    Agreed. Can we be a bit more pacific please?
    ourkidsam
    What about lemonade?
    DaveRambo
    Ooo I’ve got to add to this
    Water is the common name for the chemical with the composition H2O in the same way that methane is the common name for CH4 etc
    The properties of ‘water’ are exactly those exhibited by the molecule H20 – by definition.
    and it’s not possible to give a definitive answer to “How many molecules of water are there in the Ocean” – It will be constantly changing to the point where it’s not possible to answer. The best you can do is give a rough estimate and even that will be extremely difficult to validate.
    This leads to the only possible answer being as Sawyer eloquently put :
    Lots.
    Peyote
    Cool, a natural soda stream!
    It was one of the theories as to why ships kept disappearing in the Bermuda Triangle too. Not sure if it was carbon dioxide, but it worked on the principle (or is -al?, always get those two mixed up) that gas bubbles lower the density of water and allow stuff to sink.
    Not sure how it caused planes to dissappear either. Probably why I never found out if had any evidence to back it up.
    crazy-legs
    Boring. Putting just the right amount of gin in your goldfish bowl makes your fishes eyes bulge out and causes it to swim in an amusing manner.
    gonefishin
    That gas was methane released by melting methane hydrates, which is sort of a form of ice. That being said, there is no such thing as the bermuda triangle in that context as there are no more shipping accidents there than anywhere else in the world.
    dazzlingboy
    I need a pee reading this thread.
    mudshark
    Putting just the right amount of gin in your goldfish bowl makes your fishes eyes bulge out…
    Adding ice cubes to see how much cold the fish can cope with; leads to the saying – ‘The ice cube that stopped the gold fish swimming’.
    Peyote
    Another of my childhood myths is destroyed, I spent hours poring over books/magazines/articles about stories of Kraken, aliens, firestorms, secret military experiments and the ilk swallowing liners and jumbojets.
    Oh well. Everything goes the way of Santa in the end.
    molgrips
    Oh, really?
    Bermuda triangle = people trying to sell books, articles and crap documentaries desperately trying to prove that because a handful of incidents happend near to each other that means that it’s aliens or some rubbish.
    simonfbarnes
    underwater gas pipelines have to be carefully covered and monitored as a leak can cause passing shipping to sink…
    no_eyed_deer
    [pedant] That should be ‘could cause passing shipping to sink’, shouldn’t it sfb? I’m not sure that it has ever actually happened? [/pedant] 😉
    Interesting bit of info though
    cheese@4p
    Then the ship might sink onto the pipeline, smashing it up and causing a huge gas leak which might have devastating effects on the climate, and that….
    ahwiles
    Peyote – Member
    “There is a spring somewhere in South America or Indonesia which spews out carbonated water”
    there’s one of those near bubion in spain – i drank from it when i went riding with switchbacks.
    it tastes beautiful.
    other sierra nevada riding holiday companies are available…
    water is not a molecule
    He’s right you know.
    It’s an element, like earth, air or fire.
    gonefishin
    No they don’t. Well they are generally buried but not for that reason. Besides they are normally only buried a few hundred millimetres which wouldn’t be enough to impede the escaping gas were the pipeline to suffer a catastrophic failure.
    simonfbarnes
    it’s not to impede the gas but to cushion from impacts by trawlers and anything else that might otherwise damage the pipe!
    boxelder
    Incorrect: One grain of sand is silica, sand is the collective term for the granular material it is a constituent of.
    Sand is a measure of texture – it doesn’t have to be silica. Most of it is silica, as that is a common, hard wearing mineral.
    Water molecules?? Life’s too short…….
    gonefishin
    Well yes but that’s totally different to
    …a leak can cause passing shipping to sink…
    isn’t it.
    zokes
    STW in the 1700s
    dandelionandmurdoch
    I remember learning form one of Jim Al-Khalili’s telly programmes that:
    “There are more molecules of water in a single glass of water than there are glasses of water in all the oceans of the world.”
    Completely irrelephant to this thread, but that dude’s such a great presenter of some fine BBC programming that I had to mention it.
    As you were.
    mikey74
    I think I did say as much in a following post.
    But ice and steam only have the properties they have because of the bonds between the molecules, which are relatively weak. In fact the reason why water can be so easily transformed into it’s different states is because of the weak bonds between the molecules.
    gonefishin
    Actually it’s quite difficult for water to transform between the liquid and gas phases and takes a huge amount of energy to boil (2500 kJ/kg at 0C and 2257kJ/kg at 100C). In fact were it not for the hydrogen bond (I’m guessing that that’s what you you are refereing to) then the boiling point of water would be much lower than it is.
    molgrips
    Mm yes and liquid water has an extremly high heat capacity compared to most other things which is why it makes such an excellent coolant.
    We take it for granted but it’s actually a very strange substance, water.
    Another factoid – there are more water molecules in a glass of water than there are stars in the universe.
The topic ‘How many molecules of water are there in the ocean..?’ is closed to new replies.
