Could trash a set of Super Tacky HR’s in under 10 days in the Alps, Super Tacky minions would do 3 months in the lakes of hevay riding. Others forever
+1
First thing to go is the sharp corners. That happens pretty quickly and you’ll lose some grip. Not much you can do about that. Then the wear starts and the knobbles get smaller. More on the back ime, then you just need to decide how much wear you can live with before replacing. If you keep a tyre long enough the rubber does lose its flex and subsequent stickiness. Never happens on an MTB tyre as they wear out first but I have had it on slicks.
+1
Although I suppose it’s possible to wear through the outer layer on triple compound tyres too. Dual compound might last longer as they only put the sticky stuff on the edges.
Depends how fussy you are, I’d buy fancy new tyres for a holiday, because £60 out of £600 is small change for the improvement. Week in week out, I’m happy just running the same tyres until they look worn and conditions change enough to justify new ones. So depending on use that might be 1 summer or 1 winter, or a couple of years if I’ve 2 or more bikes at the time.
In terms of just going off in storage though, not in any great hurry, they don’t like sunlight, but just sat in the shed they’ll wear out quicker than that unless you really do never ride them.
