How heavy is your h...
[Closed] How heavy is your hardcore hardtail?
[#5250242]
Just weighed mine with the ultra-reliable poundshop luggage scales - 32lb. Mountain Cycle Rumble with SC Shivers, Hope Pro2/321 wheels.
Posted : 15/06/2013 8:04 pm
Cham with 140mm Thors is too heavy at 27lbs, looking to loose weight, wheels I think
Posted : 15/06/2013 8:08 pm
haven't got all the bits yet, but hoping for 29lbs ish, knowing me it will end up a few lbs heavier though
Posted : 15/06/2013 8:10 pm
I used to have an NS Surge with dh wheels, Domains, and a dropper post - came to just under 35lb. It was so much fun though.
Posted : 15/06/2013 8:13 pm
Bout 28-29lbs. I don't really care. 🙂
Posted : 15/06/2013 8:15 pm
Hate the term "hardcore hardtail" but I suppose Mmmbop is one, weighs around 27lbs.
Posted : 15/06/2013 8:23 pm
I guess if I weighed it it'd be about 30lb.
The physics don't add up though, the damn thing keeps flying up off the ground like it weighs nothing at all.
But then, that's Chameleons for you.
Posted : 15/06/2013 8:24 pm
 jwt
4-5-6 around 27-28lbs?
Posted : 15/06/2013 8:27 pm
If my (Lynskey) Ti456 counts, then I think it's under 26lbs, but I'm not *that* hardcore.
Posted : 15/06/2013 8:34 pm
My Mk 1 Dialled Alpine with 150mm Marzocchi Z1 forks, big brakes and reasonable weight wheels comes in at just about 30lbs. Might try and get a lighter fork but £700+ to loose a pound and a half seems very expensive.
Posted : 15/06/2013 8:35 pm
My Evil Sovereign is now 27.8lbs. There might be a 1/4lb more to lose, but no more and I'm not convinced the cuttent tyres are right either.
Posted : 15/06/2013 8:39 pm
Never thought to weigh it, Ragley bagger, lyriks and cheap Alex fr wheels (for now) has gotta be about 30lbs mark, although the speed I drag it up hills you would think it was more like 50lbs.
Posted : 15/06/2013 9:49 pm
Weighed mine at 25lb with Whyte 19 ally frame, hope hubs/ztr rims, reverb post, xtr cranks, 1x10 gears and fox 140 forks! Rides a dream and people keep telling me to get a full sus but they always seem to be behind me going up and down. Think i should say they need a hardtail, only way!
Posted : 15/06/2013 9:53 pm
I ride a bog standard 2010 Rockhopper but regularly whip people riding £3K S-Works!
Edit - with Steel stanchions
Posted : 15/06/2013 9:54 pm
My Yelli is 27lb.
Sov. 27ish lbs
Posted : 15/06/2013 9:55 pm
Kona Explosif 650b (forks off to be 140mm u-turned) at 28lbs +- 2 lbs or something like that.
Posted : 15/06/2013 10:00 pm
Genesis Alpitude with Talas 36's and Stan's Flows - 13.9 kg/30.5 lbs
Posted : 15/06/2013 10:05 pm
C456 26.5lbs
Posted : 15/06/2013 10:13 pm
about 30 lbs I reckon.
Posted : 15/06/2013 10:14 pm
18" C456, coil RS pikes, hope pro 2/ex721s slx groupset.
28lb 7oz.
Could easily shave 1lb on both forks and wheels but its currently serving me well!
Posted : 15/06/2013 10:21 pm
my cove stiffee (with 130mm z1 freerides, pro2/xm321, 2.35 high rollers and easton bar/stem) is around 31 lbs. but i'm taking it apart and selling it in the next week or so. it's a fun bike, but surplus to my requirements these days.
Posted : 15/06/2013 10:25 pm
 LoCo
26 lbs with light wheels on 29 lbs with bigger stronger wheels and tyres, 853 dialled Albert .
Posted : 15/06/2013 10:27 pm
XS BFe, Marz 44s, Flows, Reverb, beefy (!) build. 29lb on pretty reliable scales. Light enough to run 1x9 and ride all day. Strong enough not to break so far under a clumsy rider.
Posted : 15/06/2013 10:28 pm
Soul with Float 140s, Zee 1x10, M4 brakes, Flows, UST Rubber Queens, Gravity Dropper; 26.8lbs. Started out a much more XC build but has since shifted over to stiffer, stronger and often heavier parts, which suits how I ride. Not too slow uphill, quicker downhill, when I'm on form! 😉
Posted : 15/06/2013 10:33 pm
Large C456 weighing in at just under 25 lbs.
Posted : 15/06/2013 10:37 pm
27.2lbs for my core 40, only 120mm mind so dunno if that constitutes hardcore, whatever that it...
Posted : 15/06/2013 10:49 pm
 OCB
I'd guess my small, but absurdly overbuilt DunCon Pitbull with it's big old Manitou Shermans, and big everything else comes in at... at least ~35lbs. Possibly why it only goes out down the local woods / track these days (often, going off down things on it's own). 😉
Posted : 16/06/2013 8:34 am
It's not particularly 'hardcore' to ask. Frankly I'm offended.
My Blue Pig X only weighs *that much*, but it looks like it should weight *[i]that[/i] much*. The Revelation makes a big difference, but I'm still a bit envious of the OP's Shivers.
Posted : 16/06/2013 10:12 am
C456, talas 150's, crosstrails&rubber queens and formula 203mm rotors. 25lbs on the nose.
Posted : 16/06/2013 10:27 am
I weighed my Cove Stiffee in at 14 and a bit kilogram with a mainly slx and rockshox sektor air build.
Can I suggest you take that 130 mm fork off and put a 150 mm travel on it . You'll never want to sell it. 🙂
Posted : 16/06/2013 10:43 am
22lbs for the new build Corratec SS
Posted : 16/06/2013 10:46 am
Orange Pure 7 with Pike Airs, Pro II hubs/717 rims and SLX transmission here. It weighs in a smidge over 28lb by my reckoning.
It's not as hardcore as some, but it's a brilliant all-rounder.
Posted : 16/06/2013 10:48 am
 Euro
Large steel 456, 36 talas, 1x10 and no idea really. I doubt it'd be under 30.
Posted : 16/06/2013 11:41 am
24lb 15oz for my mmmbop, that's with proper tyres, a dropper and v12 flats.
Posted : 16/06/2013 11:45 am
My Dialled PA at the back there, 31.2lbs, superstar xc wheels, Ardents, slx cranks etc.
The Ragley piglet at the front belonging to a mate , 30.4 lbs, xo carbon cranks, nukeproof/Sun ringle wheels.
The kona, doesn't count... 🙂
Posted : 16/06/2013 11:48 am
My first one a 04 Spesh P3 weighed in around 37-38lbs.
Went to steel frames and still a burly DH spec build, dropped to 34-35lbs
Went to 853 Superfly styler deluxe 🙂 and some carefull changes but the same fork/wheels, depending on tyres 31-33lbs, Been running a triple butted steel Atomlab Pimp2 which is a similar weight.
When not doing DH racing, i got a nice Surly KM, haven't weighed it but reckon it's under 25lbs, SS and v-brakes, very nice for xc and pootling about.
Posted : 16/06/2013 12:14 pm
strange...
my first double post, edited it out.
c456. So probably about as heavy as all those other ones^^^^ listed so far 😉
Posted : 16/06/2013 12:22 pm
Like that ragley up there ^^^^^
Posted : 16/06/2013 1:04 pm
Depends what it's doing tbh... My Ragley is usually trailcentry/xc-ish so 24lbs-ish. When it's being an enduro bike it gains about 3lbs of wheels and tyres.
[url= http://farm9.staticflickr.com/8381/8587569718_d0f3157b96_z.jp g" target="_blank">http://farm9.staticflickr.com/8381/8587569718_d0f3157b96_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/53860438@N06/8587569718/ ]IMAG0293[/url] by [url= http://www.flickr.com/people/53860438@N06/ ]Northwindlowlander[/url], on Flickr
Posted : 16/06/2013 9:30 pm
23lb ish for mine, i guess it may be called hardcore as it has 140mm forks, 2.35 tyres and seatpost dropper, i made it down Screel hill (nr castle douglas) last week without dabbing so yeah?, i'd consider it hardcore enough for me but i admittingly do not jump nor do i [i]gnarr to the max dudes [/i].
Posted : 16/06/2013 9:39 pm
