mboy – Member
I always leave my Revelations fully open on the compression damping. I find if I run any on it, then they feel like they spike too much. So you may have a point on a 100mm Reba. Personally I much prefer a very active fork, rather than an overdamped one, and I never use lockout either.
But I’m not especially heavy (12 stone), maybe I should be running slightly lighter oil than standard to get the desired effect in my forks perhaps?
Open the floodgate a bit.
The description Stoner has posted misses out a key point, without tuning the floodgate to a fairly light setting, you are essentially running a port orifice fork (hence the spiking).
I have my LSC (blue dial) set to about 3/4 closed, and floodgate about 4 clicks from open. This gives minimal dive, but fully active on bumps
wheeliejim – Member
On the compression stroke, does the oil go through the ports on the piston AND the port in the mo-co.
Otherwise I can’t see how the piston would move at all.
Is there any air in the equation?
Yes, the bottom part (rebound damper) has a check valve which allows oil to flow freely on compression, but though the limited size rebound port on rebound.
When the rebound pushrod enters the stanchion, it displaces some oil, this is what the swiss-cheese part acts on.
