Viewing 6 posts - 1 through 6 (of 6 total)
  • How does fork length alter geometry? And bb height?
  • Merchant-Banker
    Im currently looking at getting a new hardtail 29er frame, the geometry given on the website, is for when the bike is set up with 80mm forks.
    I want to run it with 100mm forks but i dont no how much this changes things.
    The headtube angle is 72d
    The seatube angle is 73d
    with a bb height of 11.8″
    How much will 20mm effect the bikes and its ride?
    Also on a completely different note, as the yeti bigtop comes with iscg 05 mounts,rear wheel option for 12mm,and a 1.5″ headtube. that you might get away with a bigger fork?
    Thanks
    MB
    TandemJeremy
    half a degree slacker, 10 mm higher bb approx
    20 mm longer fork = 15 mm higher ride height after sag. 25 mm higher ride height = 1 degreee IIRC
    Marginal difference
    cynic-al
    1 degree = 17mm fork length = additional length of your fork sagged (a-c being equal)
    bb height would change 1/4″
    Unlikely to make a huge difference. No idea re your last q.
    Merchant-Banker
    Thanks gents.
    cynic-al
    I’ve done the maths so am confident my figures are “da bomb”
    duntstick
The topic ‘How does fork length alter geometry? And bb height?’ is closed to new replies.
