Viewing 18 posts - 1 through 18 (of 18 total)
  • How do I know what year my Cotic Soul is from?
  • MoseyMTB
    I’m a little confused as to the age of my Cotic Soul. It’s not the earliest with the cables on the top tube but the rear mech guides are tubes not cable ties like the one (classic) now.
    Is there anyway of knowing which year (how old it is)?
    Tom83
    Cut it in half and count the rings?
    MoseyMTB
    Ah great cheers mate ill give that a go.
    househusband
    Does it have an oval top tube? Does it have a replaceable rear mech hanger?
    MoseyMTB
    It doesn’t have a replaceable mech hanger and the top tube is round.
    househusband
    Not the current Soul, nor the previous then. What colour is it?
    wonnyj
    You post a picture on here and cy or someone in the know will tell you.
    The decals can tell you something as well but I wouldn’t know exactly what…
    MoseyMTB
    Yeah I can’t find the pics for some reason and I’m home at the parents now. It has the Cotic with lines not the wrap
    woody2000
    Frame number and give cotic a buzz?
    Nobeerinthefridge
    Check your receipt?
    chiefgrooveguru
    The cable guides are still tubes, it’s the hose guides that switched to clip-in ones in Autumn 2006 (when the cables/hoses moved from above to below the top tube). So it’s Autumn ’06 – Autumn ’09. BB shell width (68mm is pre Spring ’07) will narrow it down further.
    MoseyMTB
    It’s not a 68mm bb. The cable guides are tubes for sure.
    I only run one spacer on the drive side so 73mm right?
    MoseyMTB
    Also it doesn’t have a replaceable me h hanger
    chiefgrooveguru
    So it’s ’07-’09.
    Pook
    parkes, just look at the receipt that’s still on the box it’s in.
    svalgis
    Sorry, slight highjack – was the replacable mech hangers introduced in ’09? And since then, has there been two versions (the one now sold as the “classic” (’09-’12), and the current one (’12-onwards))?
    MoseyMTB
    Pook excellent work sir. I walked into that one.
    MoseyMTB
The topic ‘How do I know what year my Cotic Soul is from?’ is closed to new replies.
