Hope XC freehub stu...
[Closed] Hope XC freehub stuck!
[#3092929]
It hasn't had a service for around 5 years and is starting to make some unusual noises.
Ive took the end cap off, and tried to lever the freewheel off with a couple of flat bladed screwdrivers - but it won't budge. I've tried to follow a few different tutorials for removing the freehub and they all say only a screwdriver is required.
Could it be seized onto something as it's not been touched for 5 years? If so... what?
Constructive advice appreciated!
Posted : 29/08/2011 9:45 am
Try popping the cassette back on and giving it a little 'encouragement' from behind.
ooerr, that sounds a bit rude, but it should do the trick!
Posted : 29/08/2011 9:53 am
Beagleboy,
Just given it some not so gettle encouragement as you suggested. I tried whacking the cassette with a 4lb hammer, using a big heavy chisel. I used a metal ruler between the chisel and the cassette to spread the pressure and minimise damage to the cassettle. I've hit it as hard as I dare (very hard) and it's still stuck firm laughing at me!
Any more (constructive) ideas anybody?
Posted : 29/08/2011 10:30 am
Is this where the cassette has dug into the freehub body?
Posted : 29/08/2011 10:34 am
Don't think so, I can get the cassette on and off easily enough. The cassette isnt the problem. The freehub body seems to be seized to the rest of the hub.
Dave.
Posted : 29/08/2011 10:40 am
Sorry but the cassette one is the best options, though it's handy if you have an old cassette to use & a piece of wood in my case - work your way round methodically. Just keep at it, I found mine to be a complete Mutha F***** (to use the vernacular) but eventually it did come off. Though I may have ended up using a pair of molegrips to try to waggle it as I pulled it off (oh eerrr missus), though they did slip off regularly and make a bit of a mess of the end cap (hardly the end of the world though).
EDIT: It's the end cap that will be the source of the issue, the freehub is "only" held on my this..
Posted : 29/08/2011 11:19 am
Your bearings have probably siezed onto the axle, drop a bolt into the drive side axle to spread the load, support the non-drive side hub shell outside of the bearing, and knock the axle through with a big hammer(don't waste time with rubber mallets etc, use a proper one as it'll need it).
Posted : 29/08/2011 11:33 am
