I have a set of Hope tech x2s. The rear caliper appears to have a sticky piston, as however I set it up, the disc always moves as the other piston hits it first.
I have only ridden them once, which I hoped might free it off but it didn't.
I have bled the brake in case it wasn't bled correctly from new, and have had the pads out and cycled the slightly sticky piston by holding in the other. I cycled it about 20 times, which slightly improved it but didn't solve the problem.
Is there anything I can lube it with to help it move as easily as the other piston? I had a search and it seems using brake fluid is a bad idea as once it dries it becomes sticky?
Paul
