Bike lights are adjustable – wow, sounds like you really are an expert in vision. Do you sell TVs or perhaps you are an optician?
I am not saying that either of you is right or wrong so there's no need to get narky & sarcastic – how do you know that none of the drivers you pass are not dazzled? Do you ask them all? Perhaps you do dazzle them, but it's not enough for them to flash you with a dose of full beam or maybe they can't be bothered?
I think what RichPenny is getting at is that fast road use requires a longer beam throw – and he sees the only way to achieve that (I am assuming) is to set the downward angle of the Hope 1 a little shallower).
Even with an adjustable angle for a cycle light, if you have a cone of light being emitted from a source point then even pointing the axis of the cone downwards you may still have the edges of it pointing upwards (depending on the angle of the cone and consequent spread). Obviously a spot type light will have a tighter angle so you won't have to angle the entire light downwards that much for it all to hit the road. With more of a flood style reflector,then even pointing significantly downwards the cone of light will still reach upwards into the trees (which dipped beams on a car don't do). Presumably it is this light that has the potential to dazzle.
This can be easily demonstrated with a set of Lumi halogens with a 12w spot/20w flood. It is possible with only a slight downwards angle on the spot for very little light to be cast upwards into the trees (most of it stays below handlebar level), but with the flood light it has to be pointed a lot further towards the ground before the light is completely aimed downwards.
Surely anyone with a modicum of intelligence can understand this? Or am I missing something?
