Thanks Chipps – your insight is very welcome.
I’m think bb7s work well and are powerful, but due to fixed piston unless you get the qr exactly right everytime they can rub (esp if you run then firm with minimum lever pull) as they don’t auto align like open hydraulic systems, also they don’t auto adjust for brake wear and are not as ‘fit and forget’ as hydro brakes (some may argue this point but this is my view)
I also know hydro road shifters are on the way (SRAM red this year?) but as I run a road bike for all situations that just happens to have discs – so touring, centuries, fast rides etc. I run a triple and close’ish ratio cassette on the rear so you don’t get big jumps in gear ratios, SRAM is double specific and I doubt shimano will ever release a triple/hydro shifter as it’s very likely to be di2/hydro only.
Hence the interest in something like the hope v-twin or the yet to be released U.S.E system.
