no, because a rear wheel jam is unlikely to result in the OTB that a front wheel one would most likely cause ![/quote]I suspect you are in the overwhelming majority, and yet there isn’t (and never has been) a massive number of stories about rear QRs unscrewing themselves. That being the case, I can’t see that precession is a major factor in real life and that either side at the front is actually OK.
The “Trek” recall was due to some levers opening so far that it could catch in the rotor. Around half our hire fleet was affected, even though all the QRs looked externally identical. I can assume it was some sort of machining tolerance in the cam mechanism.
