Hope Pro 3 - 15mm c...
[Closed] Hope Pro 3 - 15mm conversion but not 20mm?
[#1367161]
? Therefore limiting me to Fox 15mm thru axels
Posted : 27/02/2010 6:59 pm
Yup, kind of silly in my opinion
Posted : 27/02/2010 7:01 pm
Doesn't Marzocchi also do a 15mm fork?
Posted : 27/02/2010 7:08 pm
It's because the inside diameter of the bearing is smaller than on the pro 2 so it wouldn't physically fit, the pro 3 after all was designed as a lightweight race hub so no need to be bigger than 15mm really.
Posted : 27/02/2010 7:18 pm
DT swiss do a 15mm bolt through too.
Posted : 27/02/2010 7:31 pm
"the pro 3 after all was designed as a lightweight race hub so no need to be bigger than 15mm really."
Unless you want to use maxle Rebas, which there's a pretty good chance you might.
But flip it round, most hubs aren't convertible at all so this is still better than most of the competition, right?
Posted : 27/02/2010 9:08 pm
 br
Pro II SP's?
Posted : 27/02/2010 11:34 pm
Hoops Pro 3 SP-AM4 has 20mm bolt through
[url= http://www.hopegb.com/voir_whspam4.html ]Here[/url]
Posted : 28/02/2010 12:03 am
