Viewing 22 posts - 1 through 22 (of 22 total)
  • Hope Pro 2 Hubs – converting
  • DickBarton
    Ok, I’ve managed to make a bit of a mistake – I thought I was getting a mate a set of Hope hubs that will run QR, but it turns out it is a 12mm Thru-axle rear and 15mm thru-axle front wheel – what do I need to get to convert them to be 9mm QR solutions please?
    Front I think I’m sorted, but the rear I’m unsure of – is it just the end caps or do I need a new axle as well?
    Cheers.
    nuke
    Front – Just end caps whether Evo or standard (older) hub
    Rear – Is it Evo version? End caps for Evo, axle change for standard
    nixie
    Do you want a qr through axle for the front? Stiffer than a normal Qr but fits normal dropouts. Got one for sale with appropriate end caps if you do.
    nixie
    Rear qr is 10mm btw
    akira
    Might want to swap a qr front for a 15mm front in the next few weeks.
    Goldigger
    I have loads of end caps…
    PayPal me a fiver and I’ll send you a set..
    DickBarton
    Hi Goldigger, very kind, thanks…I’m needing to work out which version of the hub it is, but I’ll be back in touch when I find out, thanks.
    Speshpaul
    If you want to swop the rear drop me a line I’ve got Pro2 and evo pro 2 qr caps for the rear and could use a 12 x 142 set up
    nixie
    Fronts are all the same. Front end caps are interchangeable between pro 2/evo/pro 4
    davewalsh
    Pull one of the end caps off and measure the axle diameter. Pro 2’s are 15mm, evo’s are 17mm.
    djflexure
    Don’t all evo’s have EVO written on them too in large letters – mine do?
    steveh
    every evo I’ve had has it written on the shell, older pro2’s are just marked as pro 2 with some small writing next to them.
    I’m fairly sure I have all the bits you need, yours for a donation to the ride Sheffield radmires fund. Email me to arrange.
    thepodge
    I have a QR rear axle for a Hope Pro 2 (not Evo) if you need it.
    DickBarton
    Definitely not Evo hubs, so what is needed for the rear? I think there are 3 offers on the thread, can someone confirm they have the bits and I’ll happily arrange payment for the bits, thanks.
    I’m also happy to buy new, but I’ve no idea what I need…and if the parts are not being used then happier to reuse them.
    thepodge
    That’s a front set, 15 to 9mm
    They surely wont work on the rear which is 12 to 10mm
    Goldigger
    Sorry pasted wrong link.. top one in this pic from the wiggle link in my amended post above
    nuke
    ^^^ nope, he’s said he doesn’t have Evo
    hopkinsgm
    Goldigger
    Either way I have the QR end caps off pro 2’s at home… Thought they were all the same.. Apologies
    carlosg
    I have the full axle+ end caps that came with a set of pro2 hubs I bought years ago , I built them into a set of DH wheels so use bolt up for the rear. If you want it you can have it for postage costs(email in profile) no spare qr though I’m afraid.
    carlosg
    this is what you need
The topic ‘Hope Pro 2 Hubs – converting’ is closed to new replies.
