Viewing 5 posts - 1 through 5 (of 5 total)
  • hope mini brake olive 5mm or 6mm
  • nunuboogie
    just f’in bust the olive trying to shorten my brake hose. Do i replace with 5mm or 6mm the brake are mini’s
    ta
    simondbarnes
    Depends if you have 5mm or 6mm hose…
    spooky_b329
    What year are the brakes? Someone might be able to tell you what size they are. The 6mm hoses are the older type (my old style Minis had them) and are visibly thicker and not as flexible. The 5mm are similar in appearance to gear cable outers.
    nunuboogie
    they are the new ones last years so i guess thats makes them 5mm. Looked on the destructions but nowhere does it give the size of the hose. Would 1mm really make much of a difference?
    coatesy
    1mm will make enough difference to prevent you fitting it back together again. It’ll be 5mm you want if they’re last years model.
The topic ‘hope mini brake olive 5mm or 6mm’ is closed to new replies.
