Viewing 5 posts - 1 through 5 (of 5 total)
  • Hope Match makers and Shimano XT 780 shifters do they work together?
  • Speshpaul
    I have some Hope match makers for XT shifters and a pair of XT fm780 shifters.
    Now am I missing a trick here because I can’t get them to work together.
    do the match makers only work with older XT shifters?
    Paul
    davidxbrown
    Got exactly the same problem, reminds me now to see if I can get them changed assuming Hope now make an updated version? Plus when you take the windows of the shifter you need a special cover from Shimano and there currently on back order so for the time being i’m used good old Duck Tape 🙂
    Theres been a couple of threads on this already here and elsewhere and I think the only current solution is to re-engineer……
    pondy
    just done this myself, you need the new matchmaker mounts for xtr. they need to be marked m780-i, then you need to get the shimano i spec conversion kit. this combo works well
    paulevans
    Got my matchmakers today. For new xt shifters you need the xtr mm’s (they have xt 780 stamped on them).
    MTB-Rob
    Try Hope tech section….
    http://www.hopetech.com/webtop/modules/_repository/documents/SHIMANOshiftermounts.pdf
    There one for SRAM shifters as well.
The topic ‘Hope Match makers and Shimano XT 780 shifters do they work together?’ is closed to new replies.
