Hope hub Rant!!!!!
[Closed] Hope hub Rant!!!!!
[#227963]
over the past two months three hope hubs had died on me and my dad, mine had 15 rides on it less then 300 miles and it is compltley wrecked, it needs a complete rebuild.
i thought hope hubs were ment to last for ages. i know another guy whom i ride with, whos hubs died.
are hope haveing bad batches atm. i have got another hub which i'm running on my single speed which has done over 1000 miles and not died yet. it mainly rides cannock so its doing well atm.
is anybody else having these problems.
Posted : 19/01/2009 9:38 pm
Not me
* touch wood *
Posted : 19/01/2009 9:40 pm
I have also found that hope hubs are not what they used to be.
 ton
3rded by me.
what i want to know is how comes it is the big single bearing in the middle that always **** up on mine.
Posted : 19/01/2009 9:42 pm
hope bulbs were / are where it's at. pro2's I've not been anywhere near as impressed with.
Posted : 19/01/2009 9:44 pm
my pro2's on about a year and a half and still doing well 🙂
just out of interest, how do you wash your bikes? 😉
Posted : 19/01/2009 9:52 pm
 ton
with water..doh
Posted : 19/01/2009 9:55 pm
Just send them back to Hope and they'll fix/replace them
Posted : 19/01/2009 9:57 pm
 ton
freeloader, heh barnes...
Posted : 19/01/2009 9:59 pm
i don't really wash them, if I'm working on them I will take the wheels off and put them out of the way. put the bike on the stand and wash they frame down etc.
but generally washing them doesn't really help them. i wait for the mud to dry and bush the mud of
Posted : 19/01/2009 10:01 pm
can't fault you with your washing technique Al 🙂
Posted : 19/01/2009 10:04 pm
Just get your Dad to buy you some more wheels Al! 😀
Posted : 19/01/2009 10:07 pm
Dads running out of money fast kinda666 🙄
Posted : 19/01/2009 10:09 pm
LOl Chris I think he's bought a bit to much tbh, bit spoilt really 🙂
Chris dad is now just about single speed he bought be trek frame he is just waiting for some other bits
Posted : 19/01/2009 10:14 pm
I reckon the new Pro 2 hubs don't last as well as the old XC ons, too. of 2 pairs in the garage, 3 wheels needed new bearings inside a year whilst my old XCs lasted 4+ on the rear and 5+ on the front (still going)
You wanna know why I think this is? Simple. XC bearing on the left (they only use one size) 2 Pro 2 bearings on the right. Not rocket science, is it?
Posted : 19/01/2009 10:28 pm
 ton
pp, that big bearing lasts no time at all on my wheel.
Posted : 19/01/2009 10:31 pm
There won't be many gearies out with us soon then Al? 8)
Posted : 19/01/2009 10:33 pm
Then just think how much less the little ones will last, Ton!
Posted : 19/01/2009 10:35 pm
Maybe Hope should revert back to the older design. Can't see what was wrong with it, really. My XC hubs are 6 years old. I recently thought I'd better check the rear ratchet, pulled it apart, and nowt wrong with it. Cleaned it up a bit, stuck some fresh grease in- good as new. Ti freehub body doesn't wear like the alloy ones seem to, either.
Are you listening, Hope? 🙄
Posted : 19/01/2009 10:37 pm
My Pro 2s came out of the factory with lateral play in the bearings. Not best pleased to say the least.
Having said that, the aftersales service was good.
Posted : 19/01/2009 10:40 pm
I and others I know have had Hope products fail - hubs, lights, headsets etc. In every case the item has been replaced or repaired without question, usually by return of post. I don't feel we've taken advantage...
just out of interest, how do you wash your bikes? [;)
This is how I do mine:
[url= http://i41.tinypic.com/2eygkl2.jp g" target="_blank">http://i41.tinypic.com/2eygkl2.jp g"/> [/IMG][/url]
Posted : 19/01/2009 11:02 pm
And Simon's warranty service flies out the window. 😆
Posted : 19/01/2009 11:05 pm
And Simon's warranty service flies out the window. [:lol:]
well, after that I wouldn't claim for collapsed bearings - they last about 6 months with this treatment - but I'd send them back if they cracked or a spoke hole sheared
Posted : 19/01/2009 11:26 pm
[i]it mainly rides cannock[/i]
Given the grinding paste that was masquerading as trails at the weekend, I'm not surprised your hubs don't last
Posted : 19/01/2009 11:30 pm
but my other hub just gets ridden at Cannock and is fine atm, done over 1000 mile at Cannock in the grinding past.
my other one had 10 rides at Cannock 1 at Wales and some a local woods and it had new bearings in, ****ed completely needs new bearings pawls and springs had disintegrated whilst tearing through one of the other bearing, Axle is gone as one of them seized. then the free hub fell of for some reason while i was putting it on my bouncer.
I was like "Dad is this ment to happen" he was like wtf
Al
King of hammers
Posted : 19/01/2009 11:40 pm
Hammer time
Posted : 19/01/2009 11:45 pm
LMAO
Nice one chris 😆
I've also seen 3-4 Hope hub failures inside of 3 months, All have been repaired by Hope either under warranty or reasonably cheaply.....still they shouldn't be failing like this, Crossmax's just go on an on, CKs need a little more TLC, but again go on and on.
Hope XCs just used to last forever with NO TLC, that's what made them better than CKs. Now it would seem that both require similar maintenance with CKs significantly outlasting the Hopes.
Shame really, I like Hope stuff.
Posted : 19/01/2009 11:47 pm
i really like hope stuff to.
but my dad pays £100+ for a hub me/him expect to be low maintenance and to last a good couple of years, and we have been through 3 in the last two months.
to me hope only makes sense if it lasts, as I could get a deore hub fairly cheaply and they will require cones been tightening every once in a while, but they are a lot easier to change bearings clean them out re grease etc
so I'm going to get a new rear wheel built up with a deore hub, as it's cheaper and i will see if it lasts more than two months.
hope seem to be losing it a bit if you
know what I mean.
Posted : 19/01/2009 11:59 pm
Just buy some uprated bearings and fit em yourself, Hope hubs are easier to take apart than lego bricks. New bearings will cost you £10, cheaper than a rebuild and easier to service than Deore, much lighter too.
Posted : 20/01/2009 12:17 am
