Hope Hub Conversion...
[Closed] Hope Hub Conversion kits question
[#3610032]
Hello,
I've busted the rear wheel badly on my Trek EX9. Thinking of buying a new wheel with a Hope 2 hub.
My current busted wheel has 142 x 12mm bolt thru. As the Hope hub comes with QR, do I need the :
X12 thru or 12mm bolt thru?
ta
Posted : 26/01/2012 12:02 pm
ring hope they are very helpful
Posted : 26/01/2012 12:03 pm
X12...the end caps are a bit longer (142mm vs 135mm).
Posted : 26/01/2012 12:04 pm
thanks!
Posted : 26/01/2012 12:05 pm
Try and make sure it is a Pro2 Evo hub (not that there will be many wheels being built with older Pro 2 hubs) as they have a different design and cope with 12mm axles better.
A number of people had problems with 135mm pro2 hubs and 12mm maxle light axles.
Posted : 26/01/2012 12:09 pm
