I’ve just replaced the 30mm SRAM Cinch threaded, external bottom bracket on my Orange Four. It’s mated to a SRAM Aeffect single ring crankset.
I replaced the old BB with a 30mm Hope threaded bottom bracket in the ‘hope’ that the bearings on this unit aren’t made of cheese. However, when I fitted it as per instructions, I realised that I need to fit another spacer. I know it’s a silly question, but where should it go? Should I double them up on the drive side, or split them either side (that’s how I’ve fitted them, just want to check that it’s not going to explode).
As usual ,any advice would be much appreciated.
C.
