I want to put up a pull up/chin up bar in my garage/home gym.
Dont want one of those door frame jobbies as I wanted it in the centre of the room.
Ive got a spare 5ft spinlock weight lifting bar not getting used and I figured I could use that?. Any ideas of what I could attach it to the roof with? 2 bits of wood with the bar cored through each? or if i am gonna be jumping up to it and potentially swinging do i need somethign more robust, steel tubing etc? actually would it be a bad idea to use rope? and have it swing??
I would obviously have to attach to the roof joists but the garage ceiling is plastered so I guess I would 1st need one of those joist & stud detectors. Is there a typical spacing in the UK, 600mm comes to mind?
If this is all too complicated would I better with a wall mounted one? not much wall space left though.
Any Advice appreciated.
