A little something I’ve been working on to take the homebrew to the next level (well, not including accepting a place on a Brewing & Distilling Masters for 2017-18)
Local newsagents giving away an old ice cream freezer for free?
Perfect fit! 2 19 litre Cornie kegs, an old fire extinguisher and a welding regulator
Homebrew electronics. A temp controller that switches a couple of mains relays. One relay is the freezer plug, the second is a reptile heat mat. There is also a temperature probe. All in a waterproof box for garden electrics.
I had visions of one of those horrible working class boy done good things where they build a “only fools” themed mini-pub in their garage – but that’s ace.
bodgy » What did you use to drill through your window surround? A road breaker?
Did you drill from the inside out?
Q: is the CO2 in the extinguisher ‘food safe’?(?)
I can’t see a padlock on the fridge – hypothetically is there anything to stop me creeping round your house in the night and swapping the C02 extinguisher for a foam one? 🙂
Not that I would do that. Not when N20 and Helium are both readily available
