No it doesn't catch the tyre, though with the 2.25 Ardents it is very close i noticed last night..
Obviously the spacers as Shimano detail will move the mech further from the tyre when in the granny ring, though that is not a gear I use a lot so not sure it is too much of a convern.
Mech was catching on the crank arm itself when in the big ring, the M960 mechs have a bend in the cage, the M970 are straight. I bent the cage and it is not straight, everything shifts on the stand and it is clear of the crank, will see if all is well when i get out and test it under load.
Was more interested in why Shimano are right and I am wrong, is there a valid reason why I should do it their way and not mine?
