Hoe Pro II 10mm axl...
[Closed] Hoe Pro II 10mm axle question
[#2508900]
I've a 135mm Pro II hub with the 10mm bolt-in axle. Can I use this axle for the bolt-thru jobby, or does it have to be the Saint-type axle?
Posted : 26/02/2011 3:58 pm
Hope Pro II's 10mm conversions come in two flavours
Bolt up, which uses two bolts (one either end) to tighten the hub to the frame, and has no hole thru it so cannot be used any other way axle, or bolt thru that has a seperate 10mm axle running through it.
Posted : 26/02/2011 4:12 pm
That's what I reckoned. Thanks for the confirmation.
Posted : 26/02/2011 4:23 pm
