I’ve recently been decorating which has meant my HiFI / Home Cinema system has been dismantled, and then put back again.
I run everything through a (now old) Denon AV receiver, using the pre-outs for the front 2 channels to run to a 2 channel HiFi amp. After putting the system back together the left front speaker started to cut out intermittently, which I presumed was a bad phono connection. I adjusted the connection a bit, and all was normal until today. So I adjusted the connections again (very tight btw) and now nothing from BOTH pre-outs. Every other component (speakers, HiFi amp, CD player) has been checked and appears to be working normally. The other pre-outs (centre, sub, surrounds) all fine. Any ideas what could be wrong, and any way to fix?
(BTW Current work around to keep me going is to use the front channel connections on the receiver).
