Just bought a new enduro frame and it supposed to have 150mm forks, the question is will I get away with vanilla r 140mm? Or does anyone have any suitable for sale must be it great cond…
What year Enduro frame as recent ones use a 160mm fork?
A larger profile front tyre and/or a little less sag on your fork should make up the 10mm easily enough.
Just about to stick some Lyriks on mine so will have a set of 2008 E150’s up for grabs with a 25mm hub wheel and a triple clamp stem if that floats your boat??
No worries. Great bikes btw. Mine started life at around 28lbs but have recently added a coil shock and it rocks, so I am in the process of beefing it up all round (stronger wheelset, lyriks etc) for extra “gnar”
ive got the 2005 s works enduro and im currently running 140mm pikes on it with no disasters..
i REALLLY want 150’s on there though so im looking for a set too.
mines large with a DHX5.0 coil on the rear..it weighs just over 33lbs…
still whips my mates on their cube AMS pros…its a beast
My 2006 S-Works is a beast too. 160mm Fox 36’s, coil DHX 5, DH rims. Sadly it weighs a ton so only gets ridden when I go to the Alps or uplift days but boy does it like it. It will go uphill under pedal power though…
I’ve had 130mm coil revelations on it years back, it was fine. I’ve had 140mm Pikes on it too, it was fine.
Your 140mm Vanillas will be fine on the Enduro but they do seem to be better beefed up somewhat. Start budgeting now and whatever you do, don’t read this….
