Help smelly Dyson h...
[Closed] Help smelly Dyson hover
[#1763964]
Smelly hover help!
Posted : 02/07/2010 9:06 pm
smelly hover?
Posted : 02/07/2010 9:09 pm
Clean it?
Posted : 02/07/2010 9:18 pm
Take it to the tip and then buy a proper vacuum cleaner that works.
Posted : 02/07/2010 9:21 pm
Take the filter out and either clean or replace it.
Posted : 02/07/2010 10:26 pm
Suck some Shake'n'Vac though it.
Posted : 02/07/2010 11:11 pm
Flaperon - Member
may not taste very nice.
They last years if you actually clean them out properly
Posted : 02/07/2010 11:19 pm
 Rio
If it's a Dyson, take it apart (it all comes apart), wash all the plastic bits, dry them thoroughly and then put it back together.
If it's a Hoover don't do that.
If it's a hover take it to [url= http://www.hammacher.com/publish/10321.asp?source=CJ&cm_ven=CJ&cm_ite=Levitating+Hover+Scooter&cm_pla=1356483&cm_cat=1219020 ]a specialist[/url].
Posted : 02/07/2010 11:32 pm
If you phone the Dyson helpline the very helpful ladies will talk you through the cleaning procedure, put on loudspeaker and job done.
Posted : 02/07/2010 11:47 pm
Have you been using it for something other than, you know, hoovering 😐
Posted : 03/07/2010 12:42 am
You can't Hoover with a Dyson. You can vacuum though.
Posted : 03/07/2010 1:05 am
I had to put the shower head down the hose of our dyson after SOMEONE sucked up plaster dust with it. After I cleaned it all out and washed the filters it goes like a mental thing again. Especially washing the thin filter that lives under the bottom of the bin (upright) replace once dry and try to keep flat.
Posted : 03/07/2010 6:45 am
Filters are washable / replaceable. RTFM. (-:
Posted : 03/07/2010 9:34 am
