So, I’ve managed to get a Mk 3 Soul frame off ebay, to replace an aged P7 frame.
I’m going to move across as much as I can from the P7, but will buy a new (2nd hand) set of forks to match the tapered headset.
My requirements are for a 15 or 20mm bolt though fork with 140mm travel.
Perusing pinkbike and ebay it seems that both late RLC and early CTD forks are available for about £250. Which is best in terms of damping and general bump compliance.
Would I be better with a last generation RLC fork, or a first generation CTD one?
Should a set of rockshox revelations be considered too? I haven’t had rockshox since going to fox in 2008, but a lot has changed!
Again, with the various damping models what would be best in terms of real world performance and cost? Solo/Dual air, RCT3 etc??
Does anyone know the MINIMUM steerer length that I would need too? I’m guessing about 180mm?
Also, dropper posts…I didn’t have one on the P7 as it had a 27.2 tube. The soul is not kitted for a stealth post, but is a reverb still the way to go? How do you calculate which length to go for too?
Thanks,
Dicky
