Hi, I have a recurring problem with my Rockshox Revelations. I keep loosing oil from the compression damper chamber down into the lower leg assembly.
Its not a predictable occurrence, it could happen the first ride out or 10 rides out however when it does occur it results in the compression damper settings having no impact on the movement of the fork- no lockout function and no threshold either. It is never a massive amount of oil in the lower leg, maybe only 5-10ml extra but the lose of volume is enough. The only way to rectify the problem is drain the compression unit and top up with oil- always the correct volume.
I have had one servicing company look at the forks and service them to no avail and I’ve spoken to another without any joy. I recently replaced the inner and outer seals on the rebound unit and that sorted it for a few rides but yesterday I noticed it had gone again.
I’ve therefore hoping the combined knowledge of STW might give me some new ideas as I’m sick of constantly having to drain the compression chamber and refill with oil.
