Thanks. I read a long thread, which also seemed to suggest that simply removing the foam ring from the air plunger would solve it. However, a quick chat with the nice lady at Mojo pointed me at the correct replacement wiper seal, which is only a quid. Since I needed to order some float fluid and crush washers (which I always lose!) I stuck one of these on the order as well. So, hopefully it’s problem solved.
Just draining some oil out of the top (through the valve) had a dramatic effect though. I guess this is one of those problems that sneak up on you and the fork gets gradually more harsh. I’d just assumed that I was riding even more crappy than usual, but it turns out that I’m exactly as crap as I’ve always been, which is nice.
Thanks for all the advice.
