Ok, apologies in advance as i’m not that technically minded!
I have a Zesty 327AM 2014 mountain bike and its making a dreadful racket!
I gave it a good clean down earlier and put it on the workstand to investigate. The noise is coming from the back wheel hub and sounds like a grating / scraping noise which is apparemt when i turn the cranks in a forward direction. It doesnt happen if i turn them backwards which makes me think its related to the cassette.
Tomorrow night i am planning to take the wheel off, remove the cassette and clean and grease it. Do you think this is likely to solve the issue or is it more likely to be something more complicated?
Or as is suspect, have i failed to give enough info for any reasonable diagnosis!!
Thanks – if you have any (sensible) pointers / suggestions then they will probably be very welcome!
