Its all on the website. I have NN’s & Ralph EVO sealed fine on Amercan Classics & Single Ringles Black Flags (the latter are a licenced STANS design).
As per the NoTubes website,tape the rim if necessary, leave the last bit of bead, throw in (probably 2) scoops of STANS fluid, seat the tyre and punp like crazy. old the tyre horizontally with the bit away from you pointing slighty downwards and shake. Rotate tyre 6 inches and repeat. Flip wheel and repeat (adding more air if necessary. The no tubes site has a video showing this.
That ^^ is probably the most you’ll have to do – I’ve had NN TLR’s and Bonty Mud X seal instantly without all the shaking (although I did it anyway to be sure).
Edit here – the “tubless kit” vid
