Okay, I have a couple of issues with my house. Basically I hate the maoney pit….
But seriously, my wife tells me the roof is leaking. I’m not convinced (haven’t had a look yet) it is and think it may well be moisture condensing up there?
The roof was coated by the previous owner using some horrible looking product (Aquashield – bunch of cowboys) and I suspect this hasn’t helped the issue. But I don’t know what it was like before so….
The house is about 40 or so years old. Standard box with windows, concrete construction, tiled roof. It’s double glazed with with aluminium framed double glazing which is in good condition, although there are no window vents (another issue…)
The insulation in the loft may as well not be there. It’s like a paper type stuff and pathetically thin. I was planning on properly insulating it and flooring it so I could use the space for storage when I get back from India.
However if it’s leaking/condensing/something else then I need to sort this out first.
Any ideas, is this a common problem with next to no insulation in place? She tells me that there are large damp patches all over the place. Between the rafters there is what looks like some cheap fibreboard type sheeting – this is where you can see most of the damp patches.
If I use heavy insulation in the loft should this cure it? I know it’ll save quite a bit on the heating bill…..
Thanks
