Hi Guys,
I’ve got a pair of Avid Elixir CR brakes and I’m havin a real tough time with them.
I’m (usually) pretty good at bike maintenance but this time I’m stumped.
The rear brake feels very spongey at the lever and it will pull right to the bar. It doesn’t seem to get a good grip on the disc at the calliper end and if I try hard, I can rotate the rear wheel with the lever fully pressed in so I’m not getting the power I need out of them.
Now I have bled and rebled the the back brake too many times. I first bleed the hose with the lever out, pushing fluid from the calliper end and all OK. I then bleed the calliper with the lever strapped to the bar, again, seem to get all the bubbles out and all seems OK. Then I slowly release the lever whilst pushing the calliper syringe as instructed. Then take off the calliper syringe and close it up.
Now, when I come to bleed at the lever end, it seems to want to draw and endless amount of bubbles up when I give it negative pressure. I can also hear a squeak near the lever pivot when I do this.
So, I’m pretty sure the lever is the problem and I’m pretty sure there’s a leak at the lever end with the squeak of air going into the system. I also noticed that when I went to put the bleed port screw back in at the calliper end before I bled the lever, the fluid kept dripping out of the port. Correct me if I’m wrong but that surely means there’s a leak in the system somewhere?
I think my next move is to get a new lever kit. I took the lever apart using the avid instructions and had a look at it all but it looks fine to me. I am assuming that one of the seals has gone.
Has anybody else had this problem or knows what’s going on?? I’d like to think I know what I’m doing with bikes usually but this one has me frustrated. Help Please!!!
Thanks, JT
