And so it goes on…….yawn.
I’m not a heavy rider only 12st in old money but I’m something of a fork whore so I’ll tell you:-
I’ve run the self same RS Sektors (coil U turn) in both 20mm & 15mm and I still have them. Further more on one bike I’ve run the 20mm sektors for a while and then 15mm Revs – same travel and chassis just different damping and spring. On another bike I’ve run the 15mm Sektors for a bit and then 15mm Fox 32 both coil but the Fox’s are 140mm vs sektors at 150mm (although normally run at 140 on that frame)Also to note is that on both bikes, bar height, bars & stem are the same (even the same make).
Having had the luxury of making comparisons (this is potentially even better than so called magazine tests! :o))and I still have all the forks – yes in total I currently have 3 bikes but 8 forks and I sold 3 forks last year, there is soemthing wrong with me ! – these are my conclusions:-
20mmRS vs 15mmRS – I can tell there is a difference BUT only if I think about it or look for it while playing about. The 20mm is stiffer, it is a little more ‘precise’. if I’m out riding it isn’t noticeable. I never think that would/wouldn’t happen if the axle was bigger/smaller.
15mmRS vs 15mmFox – Cannot detect any difference ever, with regard to steering precision, flex and so on.
The big differences I find are:-
1. Tyres.
2. Tyre pressures.
3. Damping – the difference between MoCo in the Sektors RL’s (2011) compared to the MocoDNA (& maybe the dual flow rebound)in the Rev RLT’s (2012) (and for that matter the Fox OB RLC – 2009) is apparent in several ways, but the Sektors are fine at least 80% of riding.
4. Riding style !
All this IMHO 😉 of course.
