Morning peeps
The big boss has given the go ahead to buy a new frame, a nice shiny on one 456.
the plan is to build it up from my prophet parts for the winter, main snag though is headtube lengths. The Prophet is 110mm, the 456 (20") is 120mm, I run a thomson stem 40mm and 15mm of spacers. Making the steerer tube about 190mm.
Dropping the spacers would give me 28mm to fit a headset, wanted to fit a hope, same as the prophet making it easier to swap, but the stack heights to high. Whats out there around 28mm stack height?
cheers
I'm also watching the other on one post about the sizing because I'm not sure on sizing either, though living near sheff, might just pop over to the showroom in rotherham and see if I can sit on an 18" and a 20" to compare. Me I'm 6'1.5" with a 33" inside leg
