Building up a On One Lurcher 29er carbon. I’ve not fitted my own headset for some time and am not up to speed with the differences between integrated/semi-integrated/internal etc.
According to the On One website I have a Mixer Taper head tube and need a Smoothie Mixer standard (44mm upper, 49.6mm lower)headset. I don’t want to fit the smoothie mixer (which apparently is: Semi-integrated (frame bore 44mm) top
External cup (frame bore 49.6mm) bottom).
Can someone please point me in the direction of a correct sized alternative that is light, lasts well, and is not uber expensive? Thanks.
