Ok, to the best of my knowledge this is how i’d define the headset.
1-1/8 and 1.5 inch Threadless, Campy style upper and 1.5 inch lower cartridge bearing
TOP CUP
1 1/8 campy style (i believe this is just another way of saying Intigrated headset)
You will be able to tell if it is an Intigrated headset as the upper cup(the bit the bearing sits in) in your case it will most likely be formed into the frame and not a removable part.
LOWER CUP
1.5 inch lower cup with reducer to take strait 1 1/8 forks, i can not tell from the pictures i have seen of the bike if the lower cup is internal or external.
Hope now do pick and mix headsets so that you can buy the correct bits for your bike. Take a look at this document that takes you through the full range of headsets they do. This will hopefully help explain what you have but please don’t take it as gospel.
http://www.hopetech.com/webtop/modules/_repository/documents/HOPEHEADSETS2011Web.pdf
