Trying to fit a semi-integrated headset for a 1 1/8 steerer. I have a headset press, but the problem is that the cups have a bevelled edge where the bearings sit and my press has a square edge, so although it is the right diameter, it slides a little in any direction, and that is making getting the cups straight really impossible.
I could put the bearing in and do it with that in place, but that would probably damage the bearing as the pressure would not extend as far as the outer-race. The old bearings I took out were ball and cage, so I can’t use them, anyone got any ideas? A massive washer would be an option, but I don’t have one of those either.
Its a cane creek 40 series if that helps any…
